2 posters
    Ecu issues
    WickeDAcura
    Ecu issues Empty Ecu issues
    Post  WickeDAcura Mon Nov 19, 2012 11:41 pm
    Ok i just recently swapped motors on my integra. Put in a B16 and got a B16 ecu but the only issue is that the b16 ecu is Obd2b and my car is obd2a.. Some tell me to get a chipped p28 then some say it wont work cuxz that obd1.. What Ecus will work??
    crazyboost0511
    Ecu issues Empty Re: Ecu issues
    Post  crazyboost0511 Sun Dec 16, 2012 10:48 pm
    personal opinion - if i were you i would keep the stock ecu from the vehicle until you find the right one.unless you are planing on doing any mayor upgrades like injectors,turbo, cams, ect..future reference try and keep the wire harness with a matching ecu.always works Wink
    for the obd1 p28 chipped it could work but it will lack in air and fuel since its made for a SOHC engine. have to be careful otherwise you will end up needing a new engine.
      Current date/time is Sat Apr 27, 2024 1:56 pm
