3 posters
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build
    SQ is the SQUAD
    SQ is the SQUAD
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build Empty Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build
    Post  SQ is the SQUAD Mon Jan 30, 2012 10:15 am
    its still in the developing process
    this is not the same wagon some of yall may of seen before. i got this one Dec of 2011
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 5lug
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build Empty Re: Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build
    Post  EF9SAMMY Mon Jan 30, 2012 11:59 am
    looking good vic
    SQ is the SQUAD
    SQ is the SQUAD
    Post  SQ is the SQUAD Mon Jan 30, 2012 12:59 pm
    as soon as it get warm i am going to get cracking on some body work
    Post  RoboTron Tue Jan 31, 2012 10:24 pm
    just seeing the 5th wheels on it lets me know this wagon means business! cant wait to see future work.
    SQ is the SQUAD
    SQ is the SQUAD
    Post  SQ is the SQUAD Tue Feb 14, 2012 10:45 am
    well, things dident work out to great form last build, had high hopes for the car, it was just too far gone with rot. came accorss a better wagon body, starting all over.
    old thread
    http://honda-tech.com/showthread.php?t=2919224
    so i scored this car from craigslist. its a 1994 Honda Accord EX wagon with 96k miles on it. the previous owner said he went into the store and left it running. the heater hose blew and the needle peg all the way over to hot. he told me the head gasket was gone. i wasent to concerned about the motor, i just wanted a solid body. so i brought the car. he was asking $1000, i offered $500, and somehow we got to $650.
    so i towed the car home, started playing with it. i took the battery from my old wagon, and it fired right up. CEL is on and D4 transmission light was blinking. i noticed that he had the fans wires to run all of the time. i let it run for about an hour and dident heat up.
    the next day i fixed the fans the way they where supposed to be. i noticed he also remove the thermostat. i put a new thermostat and gasket. let the car run for an hour. got heat. needle did not move above 40%
    i been driving it for a few days. replace the water with some antifreeze, bleed the coolant system car has been running good. there is no oil/coolant mixture anywhere. all cylinders seem to be firing fine. ill compression test it over the weekend.
    i think maybe he just replaced the hose and never bleed the coolant system.
    interior was beyond filthy. started the clean up
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 17784009
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 55731690
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 67099129
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 27688536
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 33460247
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 57735262
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 44337461
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 88907897
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 17885226
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 17026736
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 49574353
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 15626750
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 64825596
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 64759858
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 71078816
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 83167031
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 95396734
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 38424425
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 77266557
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 90142432
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 57792434
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 39469170
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 13989486
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 20266567
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 64375392
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 49269329
    wiper motor needs some work, this is where they stop.
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 84597130
    but you can push them down by hand
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 36707198
    gauge cluster shot
    Turbo Vic's 1994 Honda Accord Ex Wagon turbo h22 Build 36727918
      Current date/time is Sat Apr 27, 2024 12:40 am
