Ok i just recently swapped motors on my integra. Put in a B16 and got a B16 ecu but the only issue is that the b16 ecu is Obd2b and my car is obd2a.. Some tell me to get a chipped p28 then some say it wont work cuxz that obd1.. What Ecus will work??
2 posters
Ecu issues
crazyboost0511- Posts : 1
- Post n°2
Re: Ecu issues
personal opinion - if i were you i would keep the stock ecu from the vehicle until you find the right one.unless you are planing on doing any mayor upgrades like injectors,turbo, cams, ect..future reference try and keep the wire harness with a matching ecu.always works
for the obd1 p28 chipped it could work but it will lack in air and fuel since its made for a SOHC engine. have to be careful otherwise you will end up needing a new engine.
